Hey guys, I am about to install some new pro x pistons and had a question. The box came with two rings and some other smaller circular hexagonal ring looking thing. The box mentions something about a oil control ring. Is this it and do I need to install it. I didn't notice this part when I removed to stock pistons.
I have a set of piston rings for each piston, circlips and and this extra thin hexagonal ring thing. It about the same diameter and thickness as the piston ring but it's not perfectly round. It's like they took a piece of flat wire and bent it every 1/2" to make it into a ring. It's probably nothing that I need to use but I want to make sure.
They are definitely the right pistons. This flat wire ring will only fit on the bottom ring postion and not the top. I am wondering if it might be some kind of tension spacer that goes in between the ring and piston. I've never rebuilt a banshee before but have helped out on some other bikes
Edited by bajabanshee
