whats up everyone?
thinking of doing a re ring on the shee. this will be my first one so im looking for some step by step plan. also how hard is it and how long will it take for a rookie who is mechanically inclined but never worked on a two stroke shee?
thanks
whats up everyone?
thanks
follow this pictuer guide to take your top end off...
Splitting Cases
read in your new piston kit it will give you an amount of ring gap needed per mm of bore and do the math for your bore.....example for weisco prolites on a stock bore (64mm) you need to have .010-.012 of ring gap...
to messure this put your ring in the cylinder and flaten it out using the top of the piston by pushing it down on the ring until its level all the way around, then use a feeler gauge ( you can get at sears) and test the gap, if you are less then the amount needed get a very fine file and take equal amounts off both sides of the ring until you get the gap required...
now install the rings on the pistons and make sure they are lined up with the "nipple" on the groove where the ring goes.
now go opposite of taking the topend apart to put it back together...
