JaY BooGie Posted September 26, 2006 Report Posted September 26, 2006 Would I mess the motor up in any way if I were to get the CPI big bore exhaust and K&N Filters as my first mod without any engine work? I am planning on having work done to it but not anytime soon. Would I be fine with that for now? I dont want to get the T5's and then end up having to sell them cause I switched my mind. Quote
Bansh-eman Posted September 26, 2006 Report Posted September 26, 2006 Would I mess the motor up in any way if I were to get the CPI big bore exhaust and K&N Filters as my first mod without any engine work? I am planning on having work done to it but not anytime soon. Would I be fine with that for now? I dont want to get the T5's and then end up having to sell them cause I switched my mind. you wont hurt it but your not going to get the same gain from it asyou would with porting bigger carbs and every other mod you can put into it... are you running small bore now and plan on going big bore ? Quote
JaY BooGie Posted September 26, 2006 Author Report Posted September 26, 2006 you wont hurt it but your not going to get the same gain from it asyou would with porting bigger carbs and every other mod you can put into it... are you running small bore now and plan on going big bore ? I was actually going straight to the big bore...Cause I plan on doing some work within a month or 2...Will anything go wrong with that? Quote
dajogejr Posted September 26, 2006 Report Posted September 26, 2006 What size motor (bore and stroke) are you going with in the next few months. Nope, big bore CPIs won't hurt a thing....they just won't perform very well until you make the motor to use them. Your first post is saying "not anytime soon"...but the latter says in a month or two. I'm confused... :shrug: IF it's going to be longer than a few months, get the T5s used. You can usually get them for a steal, and you really won't lose much money if anything when you sell them. They hold their value very well. Quote
r/atvshee Posted September 28, 2006 Report Posted September 28, 2006 i would hold off on the cpi's...with an unported motor ur probably only gonna get half of what you would gain.....t-5's are very good pipes Quote
Bansh-eman Posted September 28, 2006 Report Posted September 28, 2006 i would hold off on the cpi's...with an unported motor ur probably only gonna get half of what you would gain.....t-5's are very good pipes if you have plans to get a nice ports job and storke it get the cpi's now no scence in spending the money 2 times for pipes Quote
