gottago2stroke Posted September 21, 2006 Report Posted September 21, 2006 I used chase's tors elimination walkthrough, I was 99% sure I knew what I was doing... so I guess I'm not so smart for leaving that 1% to chance. Something went wrong, and I aint gettin spark. Probably a bad ground, I have yet to investigate it further... what are some common mistakes? Chase@miamiatv if you read this PM me, I'd like to talk it over with you. Any further help is appreciated. Thanks guys. Quote
dajogejr Posted September 21, 2006 Report Posted September 21, 2006 The wire you cut or disconnected going from the parking brake, strip it and twist it. If it doesn't have the parking brake wires, (forgot what year that started) look for the one going from the thumb throttle down, and cross that wire.... My buddies 98 that I just removed the TORS on a few months ago...I had to cross the wires coming from the p brake. I think it was a black/gold and green wire. Not 100% sure though... Quote
gottago2stroke Posted September 21, 2006 Author Report Posted September 21, 2006 No wire from the p-brake, but the one that was coming from the thumb throttle I removed, I followed it down and it just plugged in, so I cut the connectors and grounded them out. I really can't seem to find what went wrong.. I am currently going from my garage to my computer, and back again, trying to solve this. I wanna ride man... Haven't had my 'shee out in months!!!! I'm dying :baseball_wibble: Quote
dajogejr Posted September 21, 2006 Report Posted September 21, 2006 Check to make sure both wires are connected to the coil. Make sure both plugs are plugged in by the CDI in back. Make sure the connector under your carbs is plugged in (Stator to CDI)... Quote
Screaming Yellow Zonker Posted September 22, 2006 Report Posted September 22, 2006 go to where your cdi box plugs into the harness and cut the green wire with a yellow tracer. that is an over ride for the tors. that is about all my knowlege on tors since I dont have them. God luck. Quote
gottago2stroke Posted September 23, 2006 Author Report Posted September 23, 2006 (edited) EDIT: Problem solved thanks to Chase :baseball_mitt: Edited September 24, 2006 by gottago2stroke Quote
