I bought and rebuilt my Banshee from a buddy of mine. He told me the crank was replaced with an RZ350 crank. His original was beyond repair. What is the difference (good or bad) from the Banshee crank? I know the Banshee crank has a tendency to come apart in stock form; does the RZ crank do the same?
Any and all help is appreciated.
I have read that the RZ crank has a tad bit longer of a rod, but I don't beleive it. If you want do a search on a online fishe they are probably the same part number. I am running a complete RZ motor in banshee cases and there are no problems. The RZ crank would have the same issue as the shee crank. If you have it out get it welded if not don't worry about it. I ran an unwelded crank for over 15 years and never had a problem on a full mod shee. I would not worry about it.
Chris
No differance between the 2 cranks....none
