Hi, this is my mod list : pipe Paul Turner HI rev, rhino head, crank +5mm, cylindre ported for drag, v-force 2, reed speacer, advenced fire +4, and JP keihin 34mm carburator.
I never started my banshee with the new 34mm, i Know for jetting.
I have commended CGK needle, it is good for my set-up ?
the stock needle it is ok for ride now for rodage ?
Thanks for your answer, i know for jetting
SORRY FOR MY ENGLISH...
I run a 35mm pwk with a dek needle in middle clip position, 188 main jet, 45 pilot jet and 2 turns out on the a/f screw. Call Cascade, they run 2 into 1 setups on everything and know all the jetting specs for pj's and pwk's.
Hi, i have all main jet but i never started the banshee because i know for the needle, i go instal 155 main jet and 58pilote jet for begening... it is ok ? presently, i have just the stock 250r needle, but i have commended cgk needle and i recieved just the next week. i prefert commended cek needle but my dealer dosen't have cek needle...
but for this week end a go instal the stock needle 250r for just rod test.. but i know the resultat ... it is ok for just rod test ?
Thanks for your reply
Dude its hard to understand most of the stuff your tring to say.. . ...
Are you running a single or a dual setup?If dual a 150 main and 50 pilot with the neeedle in the middle clip is a place to start.Im running 148mains 50pilot with a cel in the top clip.If its a single iIhave no idea but would guess the sizes would be quite a bit larger.
Too bad you didnt know enough about shit to say anything usefull.
Junior, I have been racing and tuning Banshees since you were eating glue in the 5th grade.
Put this in your pipe and smoke it!
The cgk is gonna be too lean to start with, I would at least start with a dek, eej, or eek needle. clip in 4th position down from the top.
Pilot size #50 is a good place to start. 1.5 turns out on a/f screw also.
I would put a 190 main at least in it. I have a stock motor with bumped compression, pipe, and 35mm pwk and run a 188 main jet.
Make sure the float level on the carb is about 11mm.
Take it easy on it, see how it feels on the top and adjust from their. Do your main, then your needle positioning, finally your pilot and air screw.
Edited by Snopczynski
