Just installed my Topend. I started it up. It was idling way to high and there was no backpressure from the left cylinder. I figured out I forgot to put my carb crossover tube on. I installed it, and it idled fine. The right cylinder seems to get hotter alot quicker though than the left one. It has more back pressure and it smoke way less than the left cylinder. Any suggestions
i had the same problem... check your jets first of all make sure thery are the same, then check your idle screw both need to be same. after that if its still hot check the bottom screws on your jugs, mine where lose and made a leak and cause the heat. may have a leak chack all your o rings and gaskets.
