I just got a Boss Racing Billit Intake to use with my Keihin Pj34mm Carbs. I also got a set of K&N Clamp on POD filters. K&N Part # CR-3680. The problem is that the LH filter is resting on the exhaust pipe. The Pipes I am running are FMF SST's with Turbine Core 2 silencers. I got a set of those cascade heat shield sleeves on right now. Is it ok to let the filter rest on the pipes with these heat shields or should I be looking for new filters. The filter is an oval tapered shape with a straight base. The RH filter is close to the heat shield but it isnt resting on it. I dont know if a round filter with an angled base would help or not.
Curent filter dimentions.
Base 4.5" X 3.75"
Hight 6"
Top 3" X 2"
The base is straight not angled
Thanks for your help.
josh
you need the round like 3inch in diameter or 4 cylinder k/n with angled mounts.
that one you have is way too big for 2 carbs not enough room i would think.
