dajogejr Posted August 4, 2006 Report Posted August 4, 2006 A. What do your plugs look like after a WOT run? B. 22 inch snow shows...well...you might be better off with a 14 and a tooth or two less in the rear, IF the bike is jetted correctly... That's a big tire. I'd be surprised if it didn't pull that...though... Quote
J-Madd Posted August 4, 2006 Report Posted August 4, 2006 A. What do your plugs look like after a WOT run? B. 22 inch snow shows...well...you might be better off with a 14 and a tooth or two less in the rear, IF the bike is jetted correctly... That's a big tire. I'd be surprised if it didn't pull that...though... A. I haven't checked them (stupid, yeah I know). I have oil on my silencers, so I assume I'm at least rich enough. B. That IS a big tire (and it swells up even taller at higher speeds to probably a 23 or 4..maybe that's part of it) but the 22x11x8 10 paddle extremes that I'm going to run are the same size. That's mainly why I asked about the 15t. My Cubs are stock stroke if that matters, Thanks :baseballcap_blue: Quote
dawarriorman Posted August 4, 2006 Report Posted August 4, 2006 It should pull a 16 tooth fine with 18 inch tires. It will be geared a little higher than stock, but not much. You'll be 1-2 mph faster in each gear. 15/41 with 18" tires is geared lower than stock gearing on 20s. Try the 16, you'll probably like it. Quote
dajogejr Posted August 4, 2006 Report Posted August 4, 2006 A. I haven't checked them (stupid, yeah I know). I have oil on my silencers, so I assume I'm at least rich enough. You answered your own question... I'd say you're probably...too rich. But, forget the silencers, that could be oil AND water from a car wash...check the plugs... Quote
dajogejr Posted August 4, 2006 Report Posted August 4, 2006 It should pull a 16 tooth fine with 18 inch tires. It will be geared a little higher than stock, but not much. You'll be 1-2 mph faster in each gear. 15/41 with 18" tires is geared lower than stock gearing on 20s. Try the 16, you'll probably like it. He's not running 18's...he's running 22's. Big Difference!! Quote
Animalman294 Posted August 4, 2006 Report Posted August 4, 2006 Huge difference in cetrifugal weight to spin, with regards to diameter............. Quote
dawarriorman Posted August 6, 2006 Report Posted August 6, 2006 (edited) He's not running 18's...he's running 22's. Big Difference!! Read my post. Then read his original post, says 18 in holeshots. With 18's and a 16 tooth front sprocket his overall gearing will be slightly higher than stock, as in faster. And animalman is right, 18" tires are alot easier to turn, because they not only weigh less, that weight is closer to the center of rotation. Takes less force (torque) to accelerate it. Edited August 6, 2006 by dawarriorman Quote
dajogejr Posted August 6, 2006 Report Posted August 6, 2006 Read my post. Then read his original post, says 18 in holeshots. With 18's and a 16 tooth front sprocket his overall gearing will be slightly higher than stock, as in faster. And animalman is right, 18" tires are alot easier to turn, because they not only weigh less, that weight is closer to the center of rotation. Takes less force (torque) to accelerate it. True dat... J-Madd kinda hijacked this thread, and the original poster got caught up in the mix... :beer: Quote
dawarriorman Posted August 6, 2006 Report Posted August 6, 2006 True dat... J-Madd kinda hijacked this thread, and the original poster got caught up in the mix... :beer: No problem, I edited like 6 times cuz I couldn't figure out where on earth you got the 22" from, or what exactly you were talking about. Makes sense now though. Quote
J-Madd Posted August 7, 2006 Report Posted August 7, 2006 True dat... J-Madd kinda hijacked this thread, and the original poster got caught up in the mix... :beer: Yeah,..sorry about that :ninja: . It was such a similar question that I had to ask. I think the original poster has enough info make a decision on the sprocket, though. Quote
dajogejr Posted August 7, 2006 Report Posted August 7, 2006 JMadd...I've been meaning to ask you, is there anyway to shorten up that sig? Half a page on a big screen is too much. Do we really need to know about a past ride your insurance company bought cause you yard sale'd it... Quote
J-Madd Posted August 8, 2006 Report Posted August 8, 2006 JMadd...I've been meaning to ask you, is there anyway to shorten up that sig? Half a page on a big screen is too much. Do we really need to know about a past ride your insurance company bought cause you yard sale'd it... Yeah...I can take that out. I'd like to ask the same of the one's will all the pics. I like to look at most of them, but it looks bad when I'm at work with big tits all over the screen. Quote
dajogejr Posted August 8, 2006 Report Posted August 8, 2006 Well...I'm 1/2 and 1/2 on that one. How do you think your boss would feel if he knew you were surfing a 4Wheel ATV site all day, or even part of the day? Oh well...whatcha gonna do? Quote
J-Madd Posted August 8, 2006 Report Posted August 8, 2006 Well...I'm 1/2 and 1/2 on that one. How do you think your boss would feel if he knew you were surfing a 4Wheel ATV site all day, or even part of the day? Oh well...whatcha gonna do? I'd think it would be ok...................I'm the boss! Quote
dajogejr Posted August 8, 2006 Report Posted August 8, 2006 Well then...Mr. Man.... Get a better office, or change the monitor so no one can see it unless they walk around you to look... :beer: Quote
