I do believe you should be fine with that compression and advanced timing. I assume you must be on a stock head, or at elevation with an aftermarket? Personally I ran a mix of 20% race (Trick 116) when I advanced my timing by 4*, but I think most will tell you that you are fine, and I cannot say that you wouldn't be fine. If you want to be absolute positive, mix 20% race, cheap insurance in my book and a low mix like that wont make a noticeable decrease if you don't need it.
you will be fine with just 93 if your compression gauge is right
just checked your sig. 125 sounds little low for your shaved head it should carry that stock
