ive soaked some for 10 minutes before , and once the engine turnd on i let it idle for 5 minutes and then , i ripped it ....... clutch is still holdin up good
I reccomend if you can wait , to soak them the night before.
NITE - chase
i usually let them sit overnight, and toss in the steels so they're not dry either. maybe it's overkill, but i haven't been in that big of a rush to go any less. overnight sure won't hurt anything though. just make sure you use the same tranny oil you will be using in your ride all the time.
Overnight for me too!
I just dip them in and install them...at least that's how I did it on my CR125. It doesn't say to soak them in the service manual, just dip them. On the Banshee it was a 6 month build so I had all the time in the world to wait around for them to soak. Both clutches work fine.
