i have just aquired a 2000 banshee it is completely stock except for paul turner pipes and a port and polish what can i do to hop it up and make it run like a champ. want to put t6s on it also has k&n filters air box eliminated. my bad i spelled banshee wrong it was late and i guess i was more tired than i thought
Edited by fast@$$rider
DO NOT put the t6's on. They will not perform nearly as good as the pt with a port job. IMO keep the pipes you have on it now and invest in a cool head. Try doing a search also. Welcome to the HQ :beer:
Edited by IamKazam
I agree. The PT's are great pipes. I would start with some good reeds (if it doesn't already have them) and bump up compression, and maybe a adjustable timing plate.
it doesn't have reeds i was thinking vforce what exactly does a cool head do. i am new to banshees but from the little i've rode it i love it theres nothing like hitting that powerband that 2 stroke twin just screams i've raced it on my suzuki ltr450 and i was dead even with it down a little drag strip it impressed me how fast it is i thought i would walk it down the strip. i like it and can't wait to get more power out of it.
Cool head is more effective at cooling your engine than the stock one. It also gives you the opportunity to have interchangable domes and increase your compression.
some mods to consider:
anvance your timing
lighten flywheel
aftermarket impellar
better tires/rims
air filter (if it doesnt have and aftermarket already)
How you liking that ltr450?
A cool head, supposedly gives you better cooling properties along with interchangable domes in which
allows you to run higher compression. A cool head, v-force reed cages, adjustable timing plate, bigger carbs along with some racing gas would probably wake your banshee up quite a bit. :baseball_w00t:
