Will you see more performance gains from ported stock reed cages or aftermarket reeds like vforce3?
$250.00 is alot of money. Your stock reeds are capable of flowing well enough. I think vforce would slow the flow down over stock makeing them better for low to mid range.
If stock reeds out-performed aftermarket reeds then they wouldn't be selling them very long. Plus everyone would be doing that mod instead of replacing them.
Bottom line is "IF" money is an issue then have the stockers modified, but they will not out-perform V-3's or any other ones. They are designed to perform, and the stock ones are designed to "work", and they perform a bit, but not as good as the aftermarket ones. :beer:
I've got the V2's on one bike and stock ported cages with carbon fiber reeds set up with high tension on another Banshee.
VForce gives more power and better throttle response, plus a broader power spread.
It's all about how much money do you want to spend for the amount of HP your after.
My race quad gets the $$$ for the HP, while the play quad gets what 'works' (value vs. hp gained).
