woodro77 Posted June 11, 2006 Report Posted June 11, 2006 just rebuilt my top end ( hole in piston ) everything is new , even sent my botom end to a qualified shop and had all seals replaced , put it all back together and started it today, it is making noise out of the bottom end , maybe tranny . not to loud but loud enough for it not to sound normal. im scared something will blow. plz help, any ideas Quote
9603banshee Posted June 11, 2006 Report Posted June 11, 2006 Make darn sure your flywheel is tightened to spec.....If it's just a little loose it will make a terrible sounding noise from the bottom end and will definatly scare the $hit out of ya....(it's happened to me twice)....LOL! :baseball_bat: Quote
Ben350 Posted June 11, 2006 Report Posted June 11, 2006 what kind of sound? does it do it all the time? Quote
woodro77 Posted June 11, 2006 Author Report Posted June 11, 2006 flywheel is tight , the noise is all the time , as you rev it gets faster Quote
xxcrazybansheexx Posted June 13, 2006 Report Posted June 13, 2006 take your jugs off and check your crank bearings, make sure everything is tight! mine blew and now i have to get another new set of pistons, even though my old ones only have about 10 mins on them, a new head and maybe a new crank and clean the S*#! out of my tranny Quote
kawiking Posted June 18, 2006 Report Posted June 18, 2006 take your jugs off and check your crank bearings, make sure everything is tight! mine blew and now i have to get another new set of pistons, even though my old ones only have about 10 mins on them, a new head and maybe a new crank and clean the S*#! out of my tranny how much to replace crank bearing.(do it your self) Quote
woodro77 Posted June 18, 2006 Author Report Posted June 18, 2006 just had bottom end seals put in , he said every thing was in good condition. could it be clutch? Quote
gregbowler Posted June 18, 2006 Report Posted June 18, 2006 Water pump maybe ? This is what mine looked like when I changed it http://www.79camaro.com/misc/DSC00724 Quote
