I am sure someone will say this is a repeat thread. I want to see all your opinions still, here is my situation.
Bike and mods:
1996 Banshee
Mikuni 28mm Flatslide carbs
FMF Fattys and Powercore 2's.
Dyntek Programmable ignition
12 tooth front sprocket
stock sprocket rear 42 i think...
Pro design cool head
K&N air filter
K I want to know if i am geared way to low for my setup. When I drag on asphalt I am constantly shifting, its repeated like clutch shift clutch shift until 6th when i shut it down. Here is the real question: I don't want to hinder its performance in the sand. If i go up am i going to lose speed in my drag races? what is your input? Thanks
Edited by 'shee
more like a repeat comment.
lol j/k
Bike and mods:
1996 Banshee
K&N air filter
Im running 15/41.12/42 is low as hell I bet you do shift alot,I would say that ratio is really hindering your performance on all terrain. Edited by RILS
Bike and mods:
1996 Banshee
K&N air filter
What size tires are u running/
the ultimate gearing for your setup for sand would be 13/41.......asphalt would be 14/41......get rid of that 12, it's gotta be killing you!!
Itp Holeshot 20x11x9
and
20x10x8 sand sharks
[/quote I would say 15/42 would be near pefect.I found with 14/41 I was constanly shifting even bone stock.You should have no problem pulling the 15 im running 15/41 which is alittle higher and all i have is pipes and high compression and some pods and pull my ratio fine.
12 tooth **Might** be ok for 2nd gear launches in the sand...
For pavement I agree...it's killing you. Stock gearing, believe it or not...is pretty darned close to perfect for a piped/jetted stock motor shee.
When you start pulling more ponies with porting, strokers, etc., is where the gearing really can play a factor...
I'd try a 15 tooth for ashphalt drags...
I have the same mods you have xcept for the coolhead, mine is milled. I ran 16, 40 last season but it was a little bit of a struggle to start out in 2nd gear, yet then again in 6 th gear I was next to a dodge ram at 93 mph. Now I run 15 42, because I do alot more trail riding, this is a real good gear setup IMO :beer:
