cdwood37 Posted June 7, 2006 Report Posted June 7, 2006 In the front of my cylinders where the head and cylinders mate it seems to be leaking, There is a spot that looks like gas is coming out and the dirt is sticking to it. Does that sound like a leak, and how do i test for it? Quote
bansheeseat$$ Posted June 7, 2006 Report Posted June 7, 2006 Do a coolent pressure test that may work for you,Or engine leak down test may work as well. Quote
r/atvshee Posted June 7, 2006 Report Posted June 7, 2006 In the front of my cylinders where the head and cylinders mate it seems to be leaking seems like its a coolant leak Quote
cdwood37 Posted June 8, 2006 Author Report Posted June 8, 2006 could the coolant be leaking into my cylinders as well? Quote
r/atvshee Posted June 8, 2006 Report Posted June 8, 2006 there is a chance that coolant is leaking in your cylinders Quote
jankab Posted June 8, 2006 Report Posted June 8, 2006 could the coolant be leaking into my cylinders as well? Yes, make sure all of your o-rings are seated properly, you will have to take the head off Quote
