here is a pic of my plug on a WOT 6th gear plug check what you guys think? Also it bogs pretty good in the mid range and then cleans up when it get wound up? thats my needle correct? Which way do i move the clip? And how do i get to the clip an 35mm keihin air strykers any opinions and help would be appreciated.Or not i can never post pics on here. Anyways did a plug chop and the smoke ring was about 1.5mm and the color was brown but the electrode looked a yellow or real light brown color, again any input would be appreciated.
pic would deffinately help. needle is about 1/4-3/4 throttle. never had an air stryker apart but youll pull the cap with cable and pull out the slide and needle connected to it. pull spring up and carefully unhook cable from slide. take the slide and unscrew the little cable retainer thingy and tip up side down needle should fall out. hold the needle as it sits in the carb and remove clip and move up to lower the clip causeing leaner.
always clean off the carb before dissasembling to prevent shitintrusion
