hittintrees srh Posted June 4, 2006 Report Share Posted June 4, 2006 A friend and i just rebuilt the top end on his shee after it had been sitting for about a year. And it went PERFECT!! fired on second kick..... My question is, when should we check the compression? Can i do it now, or should it be broken in completely.. P.S. for everyone doing a rebuild, the search engine is hella helpfull!! Quote Link to comment Share on other sites More sharing options...
differentstrokes Posted June 4, 2006 Report Share Posted June 4, 2006 I would check the compression now, you might have something little turn into something big if you wait to long. Quote Link to comment Share on other sites More sharing options...
MYquadsFaster Posted June 4, 2006 Report Share Posted June 4, 2006 you can check the compression whenever you want...... i would do it now personally to know where your at on the rebuild. than if you have any problems down the road and go to check the compression, you will know about where it should be Quote Link to comment Share on other sites More sharing options...
MILO Posted June 4, 2006 Report Share Posted June 4, 2006 (edited) you can check the compression whenever you want...... i would do it now personally to know where your at on the rebuild. than if you have any problems down the road and go to check the compression, you will know about where it should be exactly what i was thinking... congrat's on the successfull rebuild - it's really rather simple isn't it. you gotta love 2 strokes Edited June 4, 2006 by MILO Quote Link to comment Share on other sites More sharing options...
GoSlow Posted June 4, 2006 Report Share Posted June 4, 2006 A friend and i just rebuilt the top end on his shee after it had been sitting for about a year. And it went PERFECT!! fired on second kick..... My question is, when should we check the compression? Can i do it now, or should it be broken in completely.. P.S. for everyone doing a rebuild, the search engine is hella helpfull!! can you post your compresion reading. I have a similar setup. cograt on your rebuild. Quote Link to comment Share on other sites More sharing options...
fastcar01 Posted June 4, 2006 Report Share Posted June 4, 2006 From my experiance it does not change very much after break in, maybee a few PSI. I agreee with above, check it now and you have a baseline. Quote Link to comment Share on other sites More sharing options...
hittintrees srh Posted June 5, 2006 Author Report Share Posted June 5, 2006 thanx for the advice fellow shee freeks BHQ for life Quote Link to comment Share on other sites More sharing options...
Banshee~ Posted June 5, 2006 Report Share Posted June 5, 2006 can you post your compresion reading. I have a similar setup. cograt on your rebuild. Read it again, he rebuilt his friend's bike. Quote Link to comment Share on other sites More sharing options...
