rich250rracer Posted June 2, 2006 Report Posted June 2, 2006 (edited) Complete motor that I believe was out of a '99. I got this from a fellow CRA racer but he couldn't tell me any more than that it ran. It's bored .040. This motor came with the complete '99 electrical system and carbs. Does have the normal chain break on the upper case. '87 motor with a nice hole in the cases where the right rod used to be. Tranny seems to be fine, shifts through all gears. No cylinders or head on this motor. Also included, '04 standard bore cylinders, good '04 crank, stator and flywheel that I bought on here. A good set of case halves with no chain damage. All that's needed to have 2 complete motors is a head. I was thinking about asking $1200, but will take offers. Shipping could be a little pricey. If anyone's interested, I can supply pics. Edited June 3, 2006 by rich250rracer Quote
michigan_soler Posted June 3, 2006 Report Posted June 3, 2006 any idea if the 87 tranny stuff will work in a 94? Quote
rich250rracer Posted June 4, 2006 Author Report Posted June 4, 2006 any idea if the 87 tranny stuff will work in a 94? Everything will interchange. Quote
f4istunna Posted June 6, 2006 Report Posted June 6, 2006 Everything will interchange. Will you seperate? If so what will you take for the tranny if it works in a 00,which it should. Quote
michigan_soler Posted June 7, 2006 Report Posted June 7, 2006 (edited) damn, i want the internals if it worked good... shipped to 49424? edit: also that lil plug i lost... shift fork shaft plug... Edited June 7, 2006 by michigan_soler Quote
motocrossxr Posted June 7, 2006 Report Posted June 7, 2006 Would you be willing to seperate the 04' Crank. If so how much Quote
odaen Posted June 7, 2006 Report Posted June 7, 2006 gimme pics of both motors please, very interested... [email protected] Quote
4everwantedbanshee Posted June 7, 2006 Report Posted June 7, 2006 i need the little gear that drives the water pump. do u have one. how much shipped to 60652 Quote
