motocrossxr
    1996 White/Red Banshee. Port/Polished, Trinity Pipes, Milled head.
motocrossxr's Achievements
  1. Do you still have the kick starter
  2. Do you still have any kickers left? How Much are you looking? please respond to [email protected] Thanks Rick
  3. No evidence of a plate above or below the cylinder. If the case was machined would this make it so the 4mm crank would not need a plate or different pistons?
  4. Ok. It does not stick about deck height..How do you check the squirsh? I do not have a deck plate.
  5. When you say that the piston sticks out of the cylinder are you speaking about the top of the crown on the piston or the point at which the round bore diameter of the piston meets the crown of the piston? The owner said that the cases were split and they were machined then, so is it posible for the cases to be trenched for a 4mm crank? I will measure the stroke tonight and get a better idea. Since purchasing I have put a cool head on it, however have to started it at all. I have rotated the stator and nothing crashes. with 18cc domes what should the squish be?
  6. ok. So I just purchased a 1996 bansh and the original owner said that it had a 4mm crank in it. There is prot and polish work done, owner said by trail tech. It had a stock head, it did not appear to be modified at all. The pistons are stock bore wiseco pistons. Owner sai that the cases were machined to fit the 4mm crank. HAs anyone ever heard of this? Is there any way to determine if in fact I do have a 4mm crank.
  7. Here are pics of the twist throttle. The brand is TCI billet Aluminum is great condition I am asking 30 dollars for it plus shipping so probably 35 or 40 shipped Thanks Carbs Shipped to NY will be 65.00 dollars
  8. Her are some pics For the first one $40 shipped for the second $50 shipped
  9. I am parting out my banshee and staring fresh. I have a list of items for sale including... FMF Fatty Gold Series pipes and PowerCore 2 silencers good hape no dents polished aluminum front bumper god shape no dents dings or bent, still very polished 2 different polished grills 1 brand new one used one season twist throttle with tor eliminators and cable in great shape stock carbs good clean running carbs pair of paddles GBC sand sharks mounted on douglas .190 thickness wheels 20 X 11 X 10 great shape nly used maybe 3 times total (still has little nubs) Email me or reply if interested [email protected]
  10. Would you be willing to seperate the 04' Crank. If so how much
