bansheenoobie Posted May 30, 2006 Report Posted May 30, 2006 ok' mechanic said crank bearing is gone so now i gotta rebuild. thinking a 4mil stroker but dont know if i want to go ported stock clyinders for the sleeper look or just go cub.I want a 421 but i dont think i can go that big with a stock sleeve? but if i go stock jugs im thinking passion 12 port drag setup Quote
bansheenoobie Posted May 30, 2006 Author Report Posted May 30, 2006 current setup is stock bottom end with .040 over vito's superstock pistons. Hemi head 20cc domes.no port work.dyna ignition k&n single filtertoomey t6's stock carbs but have 35mm fornew setup.wicked drag bars +10 swinarm w/wicked strut and wicked front shocks drag front wheels and tires from wicked and custom metallic silver basically want a drag machine in sheeps clothing so i can run the stock class in frame pipes and all just really want some opinions on whats the best bang for the buck and oh yeah i wanna go with the boondockeers nitrous kit also Quote
jankab Posted May 31, 2006 Report Posted May 31, 2006 current setup is stock bottom end with .040 over vito's superstock pistons. Hemi head 20cc domes.no port work.dyna ignition k&n single filtertoomey t6's stock carbs but have 35mm fornew setup.wicked drag bars +10 swinarm w/wicked strut and wicked front shocks drag front wheels and tires from wicked and custom metallic silver basically want a drag machine in sheeps clothing so i can run the stock class in frame pipes and all just really want some opinions on whats the best bang for the buck and oh yeah i wanna go with the boondockeers nitrous kit also Get rid of those t6's if you're going to use them on a ported motor, I'd get your crank trued and welded with a new bearing or bearings, then get a 68mm bore cub top end. And for pipes, shearer or cpi. Best bang for your buck. Quote
Animalman294 Posted May 31, 2006 Report Posted May 31, 2006 If you are going to the cub, and if you have the money I'd go with the 4 mil 68 bore cub. I would definitely get rid of the T-6's, I'm pushin' it with the T-5's but was told by my builder that it will work fine until I can afford better pipes........... Quote
