ok guys....i need help with this fast. im going riding this weekend and i have a problem with my gas tank. you all know where the front plastic bolts onto the gas tank right? well, the plastic thing there is leaking. i need to know how to fix it before sunday!!! PLEASE ANYONE!!! JUST GIVE ME SOME IDEAS....AND NO JOKES PLEASE!
You might try some epoxy. Make sure that the surface is free of oil and gas and see if it will seal it up. Might have to scuff the aera with some sandpaper to get it to bond. Other than that i have no idea. Unless you can find a used fuel tank locally.
Check out Home Depot or Lowes etc. for a plastic welding kit. That will make a good premanent fix. Hot glue would probably do it too if you can get it clean and scuffed up enuff.
Go to your local auto mart napa ect. and get a plastic radiator repair "patch kit" it comes with a mesh that you lay down first then with an appoxy you brush over the mesh, it hardens like cement should work good for you good luck, :D
