brand new durablues in the box 50 shipped
519434[/snapback]
Are these the ones with the steel insert or the older style with the pinch bolt?
Chase I'm either looking for a matching set, or one stock one.
Edited by Justintoxicated
steel insert if your int let me know Ill send you a pic.Here you go. :cheers:
Edited by batoutofshell
batoutofshell, I'll take those hubs. My Banshee uses a 400EX rear end anyway.
Justintoxicated, I have a set of Durablues with the steel insert, they are not new. I was asking $75 shipped, but I'm sure we can work out something. I am always open to trades.
I have stockers for $40 shipped.
Broke, what kind of condition are the splines in?
And they are not bent right?
Is that rust on one of them? hard to see fro the pic. I'll takem if you want to work something out, and the splines are good.
There is alittle bit of rust on the inside of the steel inserts. It would probably come off with a little scrubbing. They are not bent to my knowledge. The rust could not even be seen when on the axle. The splines look to be in great shape. They is a little marring on the flat surface of the hub, I don't know what it's from, but you can't see it when the wheel is on. All in all, they are nice hubs.
