bansha60 Posted May 22, 2006 Report Posted May 22, 2006 What type of clutch's are you guys running. I cant keep a clutch in my 428 to save my ass. I thought about a lock-up clutch assembly for my next mod on it. any recomendations Quote
reded Posted May 22, 2006 Report Posted May 22, 2006 Buy a Tusk clutch kit and install a lockup, your worries will be over. Quote
locogato11283 Posted May 23, 2006 Report Posted May 23, 2006 what do your clutch parts look like? is your basket grooved?is the pressure plate worn? if so, they can cause a new clutch to go bad quick. i see that your bike is a 98. are those clutch parts in it also 98 parts? i think id look into buying a magnum basket and new inner hub and pressure plate. i ran all new stuff with the FAST clutch in my 421 cub for over a year with no issues. i would also recommend a lockup. id say you are def in the power range for needing one. give FAST a call, he can set you up with what you need to get up and running the right way. 1-785-364-5325 Quote
strokrbanshee1 Posted May 23, 2006 Report Posted May 23, 2006 Ya FAST has a great clutch setup, you wont be dissapointed... Quote
