xxcrazybansheexx Posted May 21, 2006 Report Posted May 21, 2006 hey i just put a 13 tooth sprocket on my '95 Banshee and i was told that you don't have to take a link out, but i can't get that damn chain tightend up enough?!?!? so should i take out a link or would it mess up the alignement with the 2 sprockets?????? Quote
DMP Posted May 21, 2006 Report Posted May 21, 2006 Is this a used chain? Maybe its stretched out. When replacing either of the sprockets or the chain, you should replace them all. Quote
[email protected] Posted May 21, 2006 Report Posted May 21, 2006 try the search feature 1 week ago there was someone with the same problem and his thread title was " chain length " theres proper instructios in there to fix the bike and or any info you might need. no sence in repeating everything Quote
Banshee Gorilla 06 Posted May 21, 2006 Report Posted May 21, 2006 I just put on a 13 tooth sprocket in the middle of the DANG desert and did not take out a link of chain or anything.Might make sure your chain aint streched. Just My Thoughts Quote
cdwood37 Posted May 21, 2006 Report Posted May 21, 2006 If you have to take a link out then do it. Whats the problem with that, unless you want to go back to a bigger sprocket then you might have to buy a new chain. If you are dead set on the 13t then cut the chain. Quote
xxcrazybansheexx Posted May 22, 2006 Author Report Posted May 22, 2006 ok ,well i heard that if u take a link out u might mess up the alignment between the 2 sprockets, but if not i guess i will just take a link out, i appreciate all the help Quote
Animalman294 Posted May 22, 2006 Report Posted May 22, 2006 If the chain is too long cut it, if it is to short then get a longer one. No offense but this is not rocket science...........4,3,2,1,ignition............... Quote
