latheboy Posted May 12, 2006 Report Posted May 12, 2006 Both of my carb bowls are marked the same. One is marked 1-2P. the other is marked 1-2. I see a difference between the two. Under the angled pipe on the one on the left, it has a longer cast tube. The other bowl does not have this cast tube. Which bowl belongs on the carb with the choke knob on it. Also, i just bought these carbs, and they have never been run on this machine. Quote
batoutofshell Posted May 12, 2006 Report Posted May 12, 2006 p should mean pilot there will be a jet in the bottom of one amd a ball in the other the jet goes to the choke side that should be the p bowel Quote
latheboy Posted May 17, 2006 Author Report Posted May 17, 2006 I still dont know which carb goes were. I think I just got screwed again, and probably have 2 number 2 bowls. Thats what I get for buying carbs from an HQ member! Quote
batoutofshell Posted May 17, 2006 Report Posted May 17, 2006 (edited) one has a screw in the bottom on the inside that is a jet the other just has a gold ball. look again.In the bottom of your pics see the holes going down on the bowels look down with a flashlight.the jet or screw one goes on the chokeor left sida carb. Edited May 17, 2006 by batoutofshell Quote
Justintoxicated Posted May 18, 2006 Report Posted May 18, 2006 I can tell from teh pics you have a right and a left... Notice one has a pilot jet and the other does not. Quote
batoutofshell Posted May 18, 2006 Report Posted May 18, 2006 Left in pic choke bowel hows that! Quote
