MILO Posted May 18, 2006 Report Posted May 18, 2006 yep the little bungee cords work great too. that's how i cured mine. you could always just pull it off after starting it and toss it in a pocket or something, maybe even the old tool area under the seat. no more rattles, no more losing it. i've seen it done quite a few times. Quote
jankab Posted May 18, 2006 Report Posted May 18, 2006 My kickstarter has been rattling, and i wanted to know if any of you expierienced the same thing, my friend had a shee and the kicker rattled right off. so it must be a pretty common problem. I just wanted to know a quick way to fix it.. thanks in advance 513941[/snapback] Vito's makes a rebuild kit also Quote
fox_forma Posted May 18, 2006 Report Posted May 18, 2006 I just went to ACE hardware and brought the kicker assembly with me and got 2 orings that fit correctly over the shaft then reassembled it and its fine now. Quote
MILO Posted May 19, 2006 Report Posted May 19, 2006 are the o-rings enough to keep it from swinging out all the time? that was partly why i just used the bungee cord. Quote
