trinityshee Posted May 9, 2006 Report Posted May 9, 2006 just got a trx250r with a cr500 engine this thing is sick runs perfect and idles but u have to tow it in 5th gear to start it or ull break ur foot trying to kick it over it has a 86 cr500 engine has 196 psi compression does any one know of a company that makes a decompresion head for it or something so i can start it easier and if any one has a picture of how the kick start looks on theres because this one is kinda rigged Quote
Gargamel Posted May 9, 2006 Report Posted May 9, 2006 sounds like a cool quad post some pics of it Quote
chris642 Posted May 9, 2006 Report Posted May 9, 2006 Heres a compression release, i was looking for one since i want to get a CR 500 soon and i saw this on ebay. I guess you will have to contact the seller becasue that auction ended a while back, i bet they would hook you up. http://cgi.ebay.com/ebaymotors/ws/eBayISAP...TRK%3AMEWA%3AIT Quote
WALLACE84 Posted May 9, 2006 Report Posted May 9, 2006 Just wear riding boots when you start it. I have a 500 and so does my step dad. Plus you will get used to it after a while Quote
rocketboy Posted May 9, 2006 Report Posted May 9, 2006 ive ported cr500's and theres a way to add 2 decompression grooves above the exhaust port to make starting way easier and yo u really dont need any fancy expensive breakable unit machined into the cylinder Quote
txblueshee Posted May 9, 2006 Report Posted May 9, 2006 There's a trick to kicking over the high comp. bikes... 3-4 slow kicks with nothing but the gas on... then about 1/4 kick to set it at basically tdc... then just drop your foot... I've kick started a harley that way..... If it's that hard to kick over something is prolly catching... ie: piston ring.. You said the kickstarter is kinda rigged..... maybe you have a leverage problem? Mike Quote
trinityshee Posted May 9, 2006 Author Report Posted May 9, 2006 thanks guys for the replys , yeah the kicker is rigged bad the guy around me races these bikes and says i can get a kicker that was modified for this swap for 50 bucks so ill get that and try that starting method u gave me i also contacted the ebay seller about the kit thanks again dave Quote
[email protected] Posted May 9, 2006 Report Posted May 9, 2006 heh like the guy says on ebay ''come on girls, you know you wish those 250's were easier to kick! " i agree my 1983 250r with 190psi breaks my foot and then sometimes i hit my nee on the handlebars on the recoil and im injured before i even get the motor started . I can relate to your rig my " 250r" is in a 200x frame all rigged up with more zip ties then you can find at all your local hardware stores combined. Quote
reded Posted May 9, 2006 Report Posted May 9, 2006 CR 500's are not hard to start, KTM 550's on the other hand will give ya a run for your money. Quote
trinityshee Posted May 10, 2006 Author Report Posted May 10, 2006 yeah i hear you on the ktms i had a exc 300(the one in my avatar) with a milled head that had 240 psi if u didnt start it on the second kick call it a day Quote
superdave Posted May 10, 2006 Report Posted May 10, 2006 I have had two cr500.....always easy to start. Put it in second gear get off the quad and rock it back and forth in gear. As the motor goes up and down while in gear it pulls in fuel...charges the cylinder....then it will start with one kick...good luck..D Quote
2bzy2p Posted May 10, 2006 Report Posted May 10, 2006 have fun with your cr motor vibrating your frame apart and keeping it from cracking,, no counterbalencer in most dirtbike motors!! Quote
sp1tekiller Posted May 10, 2006 Report Posted May 10, 2006 yeah i hear you on the ktms i had a exc 300(the one in my avatar) with a milled head that had 240 psi if u didnt start it on the second kick call it a day 513883[/snapback] No, that is easy to whirl compared to a 550. The KTM 550 is a 2 stroke with a left side kicker. A nightmare. http://www.bikepics.com/pictures/463084/ Quote
trinityshee Posted May 10, 2006 Author Report Posted May 10, 2006 the bike doesnt vibrate hardly at all i bet the banshee i have vibrates more when running its got rubber under all the engine mounts Quote
