SAVAGE420 Posted May 7, 2006 Report Posted May 7, 2006 Hey i just got back from a ride on my shee and theres a weird noise comming from the rear when i punch it hard... i have a new chain and sprokets and carrier bearings. But i cant figure out where the noise is comming from...kinda sounds like when a sled track ratchets It only dose it doing dounuts and fast starts... Quote
MudSlinger09 Posted May 7, 2006 Report Posted May 7, 2006 grease the dogshit out of the bearings and whatever else you can find and spray some wd40 , why not Quote
NYUK Posted May 7, 2006 Report Posted May 7, 2006 chain may be jumping teeth too. check the slack. Quote
sheefreak Posted May 7, 2006 Report Posted May 7, 2006 chain may be jumping teeth too. check the slack. 512832[/snapback] Thats what it sounds like to me. Quote
MILO Posted May 8, 2006 Report Posted May 8, 2006 chain may be jumping teeth too. check the slack. 512832[/snapback] that would be my guess. better fix it quick or you'll be putting on another new set of chain and sprockets. Quote
DIRTMAN350 Posted May 8, 2006 Report Posted May 8, 2006 Yeah check the tension on the chain. Make sure you adjust it properly. Mine made the similar sound when i had the chain too tight. Quote
