g_low0885 Posted May 2, 2006 Report Share Posted May 2, 2006 i just order a +4 crank and wanted to know what else to do get the most out of it. i do mostly wood riding with some drag. i have about 800 more to spend. i was thinking about a big bore. then i was also thinking about just boring it out .040 and getting a set of carbs. i also want to get a set of noss or cool heads to go with it also. any other ideas that i have not thought of would be great or if you have some of the parts i need for sell let me know. Quote Link to comment Share on other sites More sharing options...
ogre03 Posted May 2, 2006 Report Share Posted May 2, 2006 You will want to get it ported. Porting you motor gives you a good gain in power and lets you "tune" your motor to the type of riding you do. Not to mention that with a 4 mil crank you should really have it ported to compensate for your new crank. PM "fastoys" that's Jeff from F.A.S.T. or "passionre" that's Jim from passion, both of them are well trusted builders who can point you in the right direction as well as do the work for you. Quote Link to comment Share on other sites More sharing options...
bigwill Posted May 2, 2006 Report Share Posted May 2, 2006 Yeah---what he said-thats all the info you need Quote Link to comment Share on other sites More sharing options...
sheefreak Posted May 2, 2006 Report Share Posted May 2, 2006 What kind of crank did you buy? If it is a Hot Rods, first money spent should be outside bearing swaps(TZ on right, at least a Max Load on the left) and Welded. I have the Hot Rods and from the research I have done, these are the problem areas. Then as everyone else has stated, some porting. Then you need to have the domes cut on your stock head to comensate for the increased stroke, or buy a noss head from whoever you pic as a builder and have them cut the domes to there profile to compensate for the added stroke and put you in the compression range that responds to their porting best. That should just about exhaust your extra money, if you're lucky, maybe even get you a billet impeller also. Then as soon as you get the extra money, you are gonna want a billet clutch basket for the extra power(stock one will wear fast), at least some beefier clutch springs(Toomey) if not a lockup to hook up the extra power, and then longer swingarm to keep from flipping over, which in turn will make you need a longer chain, which in turn will make yoy buy new sprockets.........I am sure you get my point. But it will all be worth it in the end!!!!!! P.S. Just called Jeff at F.A.S.T. for a chain, answering machine says he is not takeing on any more work untill June 15th. You are going to wait in line anywhere else though. Quote Link to comment Share on other sites More sharing options...
kb7kuh Posted May 2, 2006 Report Share Posted May 2, 2006 (edited) Or you could just give it to me and save all that money Edited May 2, 2006 by kb7kuh Quote Link to comment Share on other sites More sharing options...
sheefreak Posted May 3, 2006 Report Share Posted May 3, 2006 Hey, why didn't I think of that? Quote Link to comment Share on other sites More sharing options...
g_low0885 Posted May 3, 2006 Author Report Share Posted May 3, 2006 it is a hotrod crank. it has been trued and welded. where do you get the bearings that you are talking about? i am thinking about haveing jim do the morter work. i talked to him today. are there any other engine builders that would have a shorter turn around time. he said 9 to 10 weeks to get it back. Quote Link to comment Share on other sites More sharing options...
sheefreak Posted May 3, 2006 Report Share Posted May 3, 2006 You can try some others, but they are all busy. Jim, or any reputable builder will have the TZ bearings. Some people put them on both sides but they are expensive! You could try Patriot Racing, http://www.patriotracing.net/ Grand River Racing, http://www.grandriverracing.com/main.html There are many more, but all are going to be busy! Quote Link to comment Share on other sites More sharing options...
2bzy2p Posted May 3, 2006 Report Share Posted May 3, 2006 their not that expensive i payed 55 a piece for mine.. but 110$ for the piece of mind that its not gonna blow a bearing is a cheap price to pay to me! Quote Link to comment Share on other sites More sharing options...
twinzr900 Posted May 3, 2006 Report Share Posted May 3, 2006 ddracing.com they are well know for snowmobiles. i run there coolhead,pipes and port work on my 4mm and it rips! they do awesome work on my banshees. i mean yes i dont see anyone else run any of there stuff but i think there shit is great. just my .02 Quote Link to comment Share on other sites More sharing options...
Capone Posted May 3, 2006 Report Share Posted May 3, 2006 i am thinking about haveing jim do the morter work. 511243[/snapback] HELL YEAH! LOOK WHAT JIM DID FOR ME! THANKS JIM! (Sorry couldn't resist) Quote Link to comment Share on other sites More sharing options...
