rebuilt the engine this winter and has a bog at low rpms. i have kiene 34ml pj carbs,tommy t5s
20 over bore v force 3 reads with k&t intake, clamp on filters,ported and polished,
dyna fs ignition,and the noss head with 19 domes. compresion is 175 at
1000 ft above sea leval and my jetting is 50 piliot, 60 main and the needle is in the
3rd clip. im running 110 octane. the problem is at low rpms mainly in 1st and 2 gear. When i hammer the gas it wants to die but if i ease in on the gas its fine. any
help would be apreceated thanks :notworthy:
you might try dropping a size or 2 on your pilots.
510181[/snapback]
That's what I was thinking...mine bogged off idle when I had a 50 pilot in there, dropped it to a 45 and it's nice and crisp now :cheers:
the needle i dont know what kind but it takes regulare hex jets if that tells u anyting and i just went and got some piolets and mains ill change the piolet and let u know thanks
i put the 45 piliot in and did not help so ichanged it back and moved the needle to 2nd from the bottom and helped out alot thank for the help :cheers:
