That's funny, since the dial-a-jet is based off the Lectron pick-up system that has been used by motorcycles and dirtbikes, and later ATV's, for about 40 years. And a lot of 2-strokes at that. Not saying he's a poor mechanic, just might not have a lot of expirence w/ them.
Edited by pipebomb
you got to follow the instructions that come w/ it. they will tell how to set it up correctly. but it will require rejetting to where it should normally be without the dial-a-jet to use it as a baseline. and then you would use the dial-a-jet to fine tune up and down as changes are needed.
no, you'll have to jet it spot on first, as if the dial-a-jet wasen't there. It's meant to allow you the ability to adjust up and down to act like jets several sizes larger and smaller
Basically you have to set-up the carb like normal w/ the correct jets and needle postition then the Dial-a-jet is used to fine tune in the field as conditions dictate( like rapid elevation changes like up a steep mountain trail.) without the hassle of needing to tear everthing to rejet.
Edited by pipebomb
510060[/snapback]
If you jet the main jet perfect without using the Dial-a-jet then you'll not be using it at all. You will not be able to lean down (if going to higher elevation), only richen it. The way it is ment to be used is by running a couple jet sizes smaller main jets and make up the difference with the Dial-a-jet. This way it gives you adjustment in both directions
