hey guys im just tryin to figure out what to get. ive heard nothin but good about cubs, but havent heard too much about vitos 404 kit. i need the cyclinders, pistons, and head. i really dont wana spend over like 1300 and would like to use my stock crank. i was also wondering if i could use my stock carbs with open lid, exhaust, reeds, etc.
thanks
i can't really advise you on which one to go with, but with the stock crank i'm sure you would at least want to get it trued and welded before either of those top end jobs. B)
Edited by MILO
508123[/snapback]
This is in a way required if you dont want to have an issue later... :bolt:
The cub is more of a drag dune style cylinder, high top end power, not very much low. The vitos is more of a broad power band. I just purchased one that im using with blaster pistons, match ported case and a 4mm stroker 5mm long rod so soon as i get it running next week ill let you know what i think!
Just PM me next week if i forget!
