BansheeMxer#45 Posted April 21, 2006 Report Posted April 21, 2006 just got my axle in today and was wouder how to tighten the axle nut it says to put it all togther then put the c clip on then tighten the alen nut on the axle nut. some one who knows could u help me out plz. thanks Quote
odaen Posted April 21, 2006 Report Posted April 21, 2006 just got my axle in today and was wouder how to tighten the axle nut it says to put it all togther then put the c clip on then tighten the alen nut on the axle nut. some one who knows could u help me out plz. thanks 505760[/snapback] Not sure if there's a torque spec per se. I tighten them to where there's no sideplay in the sprocket hub, but loose enough to where the axle still spins without too much friction with your hand. Quote
Animalman294 Posted April 21, 2006 Report Posted April 21, 2006 Tighten it till it starts getting really tight, then if it starts to loosen up again you went to far . No, just yankin' your chain, odaen sounds correct............ Quote
BansheeMxer#45 Posted April 22, 2006 Author Report Posted April 22, 2006 got my axle in took about 3 hours. looks good ill probly go out to track soon to test it out Quote
