Well here is the story. This winter i broke down the shee and PC'd the frame got new a arms, shocks and what not. Got it back together today and i runs fine. Only problem, no headlights or tail light. What do you think the problem could be. Put in a RS timing plate, but it runs fine so i don't think that it is that.... thanks for the info. :confused:
Make sure your voltage regulator back by your CDI is hooked up, and hooked up right, make sure you didn't plug the wires in opposite spots.
Checked the bulbs...at least two out of three.. the brake light and one headlight. Both work. Checked that the stator is putting some power out, and it is right at the two plugs on top of the motor. But still no lights. So i think my voltage regulator took a shit. WHat do you think. All the conections are correct as far as i can trace them out. But with the stator putting out power that leads me to beleive that the regulator isn't working, Correct?? :confused:
Yeah.... they are good. Checked that also.. Even removed the paint off the back of the voltage regulator that i painted. Still no go. Dielectric greased the whole grounding conection. Nothing changed.
Well, when my voltage reg went bad, it fried my bulbs.... I put a meter on the front headlight connection to check voltage. It was good at idle, but as soon as I revved the motor the voltage shot up.....much higher than 12V. I believe all the regulator does is shunt some of the power at the higher RPM's to keep voltage constant If it went bad, it should blow your bulbs out.....
Have you checked the voltage at the bulbs with the motor running? Maybe you have a bad wire in the headlight circuit? or a bad switch? I would check voltage at the lights first, then at the switch to make sure there is not an open connection anywhere.
I checked voltage at the headlight and tailight... Not a thing. I think that my regulator is just shunting it all to ground. When i checked it at the conectors right off the stator... it did the jumping as RPMs went up. But it should, that's what the voltage regulator is for. :confused::cry::confused:
Question.... is the stator that controls the lights... yellow and black.. suppose to be grounded together?? I think i have found my problem if that isn't suppose to be like that. If not... back to chasing wires... again :confused:
Got the diagram.... just trying to confirm. I didn't think so... but with it bolted up and all... testing from the black and yellow at the top of the motor... electrically the same point. Or grounded together... i will further investigate... but got to be somewhere else at the moment. Update later. Thanks.
OK... with the stator completely off the shee... off from the timing plate. I have a short between the yellow wire and the center of the stator. That shouldn't be correct? Please help with any inputs. bangheadbanghead
Just talked to RS about that stator... they confirm that the yellow and black from the stator are shorted... or electrically the same point... so back to the hunt for the problem with my lights. :evil:
Edited by GleasmJA
