racer Posted April 15, 2006 Report Posted April 15, 2006 Or carbs out of sync... There was a thread not too long ago where a member had only 1 cyl running. It went on for awhile so just about every possible reason was addressed. I'd search for that. 500647[/snapback] ive noticed that. my bike doesnt idle (of my own doing) and sometimes its that little bit of throttle that will keep the right side firing and the left wont. Quote
ban1 Posted April 16, 2006 Author Report Posted April 16, 2006 ok swaped plug wires and changed from firing on right to firing on left cyl but anser me this,i can pull plug wire off left cyl and it will die but i can pull it off right and it wont and if i plug another spark plug in the wire and ground it outon the left cyl it will run on the right cylinder doesnt make any cents to me if it wont run on just right cyl if left is un pluged why will it run if left is pluged into another plug that isnt even screwed into the cylinder. maybe normal dont know. playing with it more and thinking it might be a jetting problem it idels fine but about 1/4 throtle kinda runs like shit sounds like it crapin out is this a pilot jet problem have 34mm kehien flat slides with 40 pilots and 135 mains clip on second ring from top and elevation is about 2900 ft Quote
blueshee03 Posted April 16, 2006 Report Posted April 16, 2006 (edited) try 38 pilots and clip in middle with 138 mains.i 'm at about the same altitude as you and this is the jetting i ran.at times when the temp changed i would sometimes drop to a 35 pilot. Edited April 16, 2006 by blueshee03 Quote
