motoboy17us2007 Posted April 6, 2006 Report Posted April 6, 2006 I was wondering considering there is a radiator if there was a thermo just a quick Q. Quote
Wallrat Posted April 6, 2006 Report Posted April 6, 2006 (edited) Alot of guys use a meat thermometer and make their own temp gauge if you're worried about overheating. Edited April 6, 2006 by Wallrat Quote
Polish Posted April 7, 2006 Report Posted April 7, 2006 Alot of guys use a meat thermometer and make their own temp gauge if you're worried about overheating. 497907[/snapback] finally got mine to work Quote
csrmel Posted April 7, 2006 Report Posted April 7, 2006 does a stock banshee have a tempature controlled automotive stile thermostat in the water passage somewhere, and if so, why not? seems like it would be a good idea to promote quick warm up and help to regulate the tempature. keeping it from getting too low when cruising at high speed, low throttle. Quote
Wallrat Posted April 7, 2006 Report Posted April 7, 2006 Nice Polish! What was the fix? csrmel - No it doesn't have one, but I suppose you could find a way to put one in. Out here in SoCal the coldest I can get my shee is about 150, which is about 5 degrees cooler than the optimum temperature. Might be more of an issue for the folks here living in the arctic circle. Quote
dajogejr Posted April 7, 2006 Report Posted April 7, 2006 Cars/Trucks have a T-Stat to keep the engine coolant in the engine/heater core to allow faster warm up, and heat .... However, this is a large, complex system. Many cylinders, larger radiator, etc. I'd say you don't need a t-stat unless you were running very, very cold temps and it takes forever for your shee to warm up. If you're riding in cold temps, let it warm up just a bit longer. Always a good idea to "blip" the throttle off and on when warming it up. Moves the water faster, warms up quicker.... Quote
jbooker82 Posted April 8, 2006 Report Posted April 8, 2006 If you wanted to put a thermostat on you could probably splice in a ratpro thermostat set up. You could aslo probably hook up an electric automotive temp gauge up too. It has a place for a temp sensor. josh Raptor Thermostat housing Quote
creamsickle Posted April 8, 2006 Report Posted April 8, 2006 eddy sanders racing has an inline temp guage for like 70 bucks. it looks cool is works good. I have one on my shee and love the convienance of knowing the temp of my engine at a glance. Quote
jbooker82 Posted April 8, 2006 Report Posted April 8, 2006 The guy i bought my banshee from put an automotive temp gauge in the handle bar clamp. Quote
