im working on my buddys banshee it has fmf fatty pipes 260 jets and is ported on itake and exhaust not big port but ok it has a problem picking up from idle and when u r going along and let off and get back on it does not pick up right away almoct feels like fouled plugs but they don't look real bad was wondering about the needles but don't know to much about them anyone help me
need more info elevation any other mods,lid on lid off,after market or stock air filter.more info will prolly get you quicker answers.my 2 cents :(
495421[/snapback]
that is it for mods everything else is stock not sure on elvation live it Maryland
you said the plugs "look" okay...
Why don't you just put new ones in and make sure the wires are okay. if it idles okay and then it has issues off idle does it wake up when you have it pinned or does it totally bogg and never hits powerband?
495431[/snapback]
yes the plugs look ok little on the darker side. it boggs when u let off the gas and back on. n when u start out the guy that did the port said that its like that because the jugs r ported pretty good on the intake and the cylenders r stock not much else done. he said to try and set the timing up its still stock too it even has a stock filter in it i think he just needs to upgreat somethings do u agree?
495439[/snapback]
To me it sounds like an airleak or something with the intake. that is my opinion though... Did you clean out the carbs and everything?
What compression does the motor have?
