since im rebuilding my whole motor we got to putting it back togther , the guy doing it says maybe since the head is milled .025 thousands to increase compression, which was just recently done, that i will maybe need a thicker base gasket, so there will be no pinging. But wouldnt that just cancel out the milling if u get a thicker base gasket? Or should i just stick with stock base gasket?
