I am trying to rejet my banshee because it is not running properly. When I get to full throttle it seems to bog out a little. My mods are FMF fatty's,+4 timing advance, Boyseen Reeds, Stock Carbs (280 mains, 25 Pilots), 15 tooth front sprocket, 41 back sprocket,Tors are removed, Bored .40 over wiesco pistons. It was runnig good last week then this week started running bad like it was just loading up. Please let me know where to start with the jetting or should I leave it the same and just adjust and clean them out??????????
Edited by Infamous039
Yes my compression is perfect I just rebuild the bike not even a month ago. It starts in the first kick. I live in New Jersey my elevation is 13 feet, the temp is between 40 and 50 degrees. I cleaned the carbs and noticed that one of my main jets was a 290 instead of a 280 so I replaced it with a 280 jet so now they both are the same. Its running better but still backfiring a little bit, but not much and i looked at the plugs and they were black (fouled out), I was thinking maybe from the carb cleaner that I sprayed in the carbs did that. Both pipes are popping fine and it doesnt hesitate at all at take off. Please help me?????????????
I had the same problem last year was running 280 main with 25 pilot(60-70) it got alittle colder out 10-15 degree (40-50) difference went to a 300 main 27.5 pilot got rid of the WOT bog problem but I will go back down to 280 when the weather warms up.Does yours run good till you nail it in higher gears and it sounds like its choking for fuel if so this should help.My plugs always look burn't don't know why, they don't foul out so>>>>>>>>>>>>>>.
Edited by batoutofshell
490326[/snapback]
stock pilots, 4th clip 310 adn see how it acts. thats with open filter.
if not open 290 or 300 sounds lean to me
I was running the 280 main and 25 pilots a couple of sundays ago and it was about 60-70 degrees outside and it ran fine. I have 1turn on the air screw. Yes the bike runs good unitll I get into higher gears, and its catching the power band but at WOT its starts bogging a little and back firing some. How do I adjust the needle clip?????????????
sounds like your mid is ok if your bogging starts when wot comes than I would move up to a 300 main and try it. to move the needles you need to take the carb tops off turn them upside down and pull the spring back, move the cable catch out of the groove, take out the two little screws the rest is self explained by looking at it apart.when taking apart the frist time is a pain but once you do it about 100 times you will get used to it. just be careful when putting it back together not to strip the carb tops.
