87banshee350 Posted March 8, 2006 Report Posted March 8, 2006 hi, i did a search and couldnt find anything so ill ask, its an 87 banshee with stock carbs, 280/25 jets needles are on the 3rd line the middle line, dg pipes, and im running mc-1 oil at 40:1, it runs great it just has a backfire when tacked out and the right side blows a little more smoke then the left thanks in advance for the help Quote
ellison445 Posted March 8, 2006 Report Posted March 8, 2006 Check your plugs, sounds like your lean hi, i did a search and couldnt find anything so ill ask, its an 87 banshee with stock carbs, 280/25 jets needles are on the 3rd line the middle line, dg pipes, and im running mc-1 oil at 40:1, it runs great it just has a backfire when tacked out and the right side blows a little more smoke then the left thanks in advance for the help 484041[/snapback] Quote
Banshee_Guy Posted March 9, 2006 Report Posted March 9, 2006 It could be timing, but most likely too rich. Do a WOT test and check your plug color and go from there!! Quote
ellison445 Posted March 9, 2006 Report Posted March 9, 2006 Backfire is not a sign of the bike being rich It could be timing, but most likely too rich. Do a WOT test and check your plug color and go from there!! 484386[/snapback] Quote
87banshee350 Posted March 10, 2006 Author Report Posted March 10, 2006 well now its only backfiring out of the right side its shooting a 4 inch flame out the silencer and doing it when reving it up, and it dont have as much smoke as the other side, the plugs are a light black Quote
H300F Posted March 11, 2006 Report Posted March 11, 2006 Check for leaks at the carb boots, check the spark plug wire, and coil, clean the carbs jets. Quote
banshee350twin Posted March 11, 2006 Report Posted March 11, 2006 do what they said and how the dg pipes sound ? Quote
Capone Posted March 12, 2006 Report Posted March 12, 2006 Its too lean, and if its backfiring I'd pull the head off and check the pistons, if they look pitted, then pull off your jugs and check around. How long has it been running like this? Search the forums for a "Air Leak Test". Quote
87banshee350 Posted March 14, 2006 Author Report Posted March 14, 2006 i just did a top end rebuild and swapped the carbs with better stock carbs and thats when it started, it runs better and gots more power but has the backfire. and the dg's sound good but would like to get the T5's Quote
