added FMF Fattys, K&N Clamp On's,
Changed the mains to 290's
dosen't seem to want to idle too well and plugs are dark
my elevation is 800-1000 feet above sea level
should i change needle or pilot jets??
How many turns are your air screws @?
Try setting them out @ 1.5 turns and see how that works. Try to get it to run for about 20 seconds. If that doesnt help, try 1 turn out on your screws and let it run for about 20 seconds or so to let your engine adjust to the change.
If you have stock pilot jets (25's) you may need to go up a size if you wind up turning the screws in to half a turn.
You may need to adjust your idle also. Are your carbs in sync?
With the filters off, can you look at the slides and do they open and close at the same time? Is your choke crossover tube in place? :shrugani:
:cheers:
