FLAME-MAN Posted February 26, 2006 Report Posted February 26, 2006 What could cause only one cylinder to overfueling really bad, and it won't start untill i dry the plugs up, and then it will start running bad again any suggestions? Quote
Malott 1 Posted February 26, 2006 Report Posted February 26, 2006 Did you check your float on the side that is overfueling? Your float just might need to be adjusted. Quote
FLAME-MAN Posted February 26, 2006 Author Report Posted February 26, 2006 If the float was out of adjustment would'nt the gas just poor onto the ground out the overflow when its just sitting there not running?, and I used 2 gallons of gas in less than an hour. Quote
Wallrat Posted February 27, 2006 Report Posted February 27, 2006 You sure you got spark on both sides? Stuck float doesn't always overflow but usually that's the case. My guess is spark. Quote
Shee-Male Posted February 27, 2006 Report Posted February 27, 2006 I've had the main jet fall out once, check that, and make sure your slides are in correctly. Quote
FLAME-MAN Posted February 27, 2006 Author Report Posted February 27, 2006 You were right! it was just a float out of adjustment , thanks for your help. Quote
