2strokersteve Posted February 17, 2006 Report Posted February 17, 2006 stock motor just put on clamp on k&ns I have pro circut pipes I ride sea level mabey up to 2000' I am going to run 300 mains ???????? does that sound right Quote
2003LimitedBanshee Posted February 17, 2006 Report Posted February 17, 2006 For the most part it's probably in the ball park, but quite possibly a bit small. What other mods have you done? What kind of air temps will you be running in. To give you an idea, I have my mods and jetting listed in my sig, jetted for sea level with about 60-65 degree temps. Quote
Handyman Posted February 17, 2006 Report Posted February 17, 2006 stock motor just put on clamp on k&ns I have pro circut pipesI ride sea level mabey up to 2000' I am going to run 300 mains ???????? does that sound right 474867[/snapback] I was running a 290 main with your set up but then again I'm 400 feet above sea level, so you should be right on. Quote
Dr. Overkill Posted February 19, 2006 Report Posted February 19, 2006 I have my mods and jetting listed in my sig, jetted for sea level with about 60-65 degree temps. 474869[/snapback] Interesting. I'm running smaller mains (310) but bigger pilots (32.5) and I ride at about sea level. I don't know how many turns the air screws are adjusted, and I'm running at least 1 Alba needle (as a result of my friend and I tweaking one when reinstalling ) It's a bit of a smoker, but runs fine otherwise. Would it be better to up the mains and drop the pilots on mine (it's stock internally, just a K&N & no airbox lid, PC pipes)? _d Quote
2003LimitedBanshee Posted February 19, 2006 Report Posted February 19, 2006 Interesting. I'm running smaller mains (310) but bigger pilots (32.5) and I ride at about sea level. I don't know how many turns the air screws are adjusted, and I'm running at least 1 Alba needle (as a result of my friend and I tweaking one when reinstalling ) It's a bit of a smoker, but runs fine otherwise. Would it be better to up the mains and drop the pilots on mine (it's stock internally, just a K&N & no airbox lid, PC pipes)? _d 475728[/snapback] That does sound really big on your pilot; I would probably drop that back. I was running a 27.5, with 1.75 turns out on the air screw, but switched back to the stock pilot (25) with .5 turns out on the air screw and noticed much improved throttle response. Also, if you're running one aftermarket needle, it may be hard to get your midrange jetted properly, because likely the aftermarket needle is a different design than the stock needle. As far as the main is concerned, the primary difference is because you still have the airbox with the lid removed. I have completely eliminated the airbox, running a Toomey (Uni) 2:1 filter assembly, which will flow a decent amount more air than an airbox with the lid removed, ie. bigger main. Quote
