My banshee has a miss on the right side jug. I reversed the plug wires but still no help. I have great compression on both jugs and both carbs are set up the same and just rebuilt. It idles fine and is great at full throttle but the mid range it just gets loaded up and nothing but gas/oil come out the pipes.
Any ideas??
Thanks
Any ideas??
Thanks
464023[/snapback]
try raising the clip on your needles, there what effect the mid range.
Thanks for the replys
Here is what I tried since the last email
Removed the carb and took apart but didnt see anything wrong
Took reeds out but they look fine
The needle is already on the 2nd clip down in the carbs.
I did notice the choke hose that goes from one carb to the other is getting a little soft and not fitting so good. I havent tried to start it since.
I started the Banshee up today and it still loads up on the right side. It idels OK and full throttle is OK but the mid section will shot gas out the pipe. Both the carbs are set up the exact same way. Does anybody have any other ideas??
have you changed your plugs yet? make sure the connections at the coil are good and clean. check the resistance of the wires and plug caps, either of those could cause weak spark. have you tried another set of carbs?
464330[/snapback]
Have you fixed this? Have you replaced your choke crossover tube yet?
Thanks for the info so far
To answer some of the replys I have changed the crossover tube but it didnt help and I have put in a few sets of new plugs and I tried 2 coils but both give the same problem. I think I have it narrowed down to the Carb but Im not sure whats wrong with it. I put in new jets (all of them) new main needle new needle/seat for the float the left carb seems to be working great its just the right side.
