Where to start...I was running the shee on Sunday and everything was great. Had a guy come up to me and wanted to race, so we raced and I smoked him the first run. Raced back and when I shifted to third she began to sputter I gave it a little more throttle and no response so I pulled the clutch in and killed the engine. Waited a second and went to kick and that sucker wouldn't budge. I haven't even had a chance to pull it apart but any ideas as to what may have happened or what is wrong.
TIA :cheers:
Doesn't sound to promising !! I went threw that last summer and blew the skirt off the bottom of the piston! You could actually bang on the pipe and here chunks in bottom...
463715[/snapback]
Yeah i blew the skirt off a Weisco one time in the middle of the dunes. Never siezed though. Rode the bitch all the way back to camp. Had very little bottom but came back on at the top.
not on a shee, but my kx, same as some others the piston skirt shattered and locked her up tight. no warning, just bogged out then CLUNK!! :cry:
I just got back in from the beggining of the tear down. Got the plugs out and they looked perfect. Put it on the jack and slid the trans into sixth and tried turning the wheels. They would go about an 1/8 around then jam. Just with a finger compression test it feels that its the left (if sitting on the shee) cylinder. What would cause the piston skirt to blow? What should be my next step in the tear down? Should I drain all the fluids then pull the head? Thanks
Damn ! you had better luck than I did! I was at the bottom of a mountain all way in the valley ! I had to be towed out buy a kingquad and that sucked !
463737[/snapback]
lucky to get a tow I had to push mine 4 miles through the snow,up 3 mountains at -5 degrees in Alaska! NOT!
The skirt is a good sign that the Rings needed to be replaced , drain all the coolent and start yankin ! You can also yank the pipes off and look up into the cylinders ! good view of the skirts!! :(
