I just did alot of work done to my banshee engine i need to know what all my jets should be at.
2006 banshee carburetors with purple hoses. NOT PORTED
2005 banshee cylinders with STD'S wiseco pistons.
2006 wiseco crank it is welded to.
2006 Billet Hinson clutch basket.
2006 Ricky Stator flywheel.
2006 Ricky Stator 200 watt stator.
2005 Banshee head milled .40 over or 40 over.
Timing plat set 5 or 7 d's forward
I live at sea level. What should they be?
That's a nice collection of parts you've assembled, however, nothing you mentioned will really have a major effect on your jetting. The timing plate could cause you to need to go up one size, but possibly not either.
Differences would come if you had your cylinders ported, changed pipes, possible reed changes etc.
So did you have it jetted right before you installed the T5's, or are those new as well. No offense, but still the only thing that would affect jetting is the pipes. What type of air filter setup are you running and is this new as well? If you haven't done anything to effect the volume of air in or out of the cylinders there isn't really a need to rejet, assuming it was jetted right before.
If all of this stuff (pipes etc.) is new, what is your elevation and temperature? That should give everybody a point to make recommedations from. :cheers:
So you replaced your old ported cylinders with new non ported cylinders? If this is the case and you are in florida run a 27.5 pilot, 300 main, and the needle clip 4th from the top. That should be very close.
Vforce does flow more than stock, but not as much as you did on your ported cylinders. The trick you speek of is it ported cages? Do you allready have jets? If you don't vito's has about every size and I would order several to get it just right.
Does it come with all the tips of jets?
What site can i get them off of?
O yead i have 12, 1 and1/4inch holes in my airbow lid does that make a difference?
Edited by Turbobanshee_kid
Vitosperformance.com is the site, do a search for it if that does not get you there. You have to select which jets you want and order them. I think they are 2.50 a peice. The holes in the airbox give you more flow, if you still have the stock filter I would highly suggest upgrading to save your engine.
