hey all i just did a compression test on my cylenders on both it was about 120-125 average. isnt this low since im running a cool head/w 19cc domes at about 45oo feet elevation? and i just tested it cold will it improve if i run the bike for a few minuets. also if it stays this low i can add a timing plate does anyone know about how much compression each advance adds with a timing plate
thanks for any help
thanks for any help
463071[/snapback]
Adjusting the timing does nothing for increasing the compression in the cylinder, it simply dictates at what time during the crankshaft rotation the impulse to fire the spark plug will be sent. It does however increase the likelihood of pre-ignition, and that is why you must start to run a mix of race fuel, depending on compression and amount of advance.
On the compression test, it should definitely improve if the engine is warmed up, as compared to cold. As the engine warms, the metal (pistons, rings etc.) expands very slightly, decrease the ring gap and increases the compression reading you will get.
463095[/snapback]
Hot to cold you won't notice hardly any difference. Might get like 3 or 4psi. Maybe.
its only 2 years old should it be that low in two years?
463174[/snapback]
Shit dude, i go through a set of rings every couple months. I ride my shee all day almost every saturday and sunday. Not just little putt around, I romp on the thing all the time. I would LOVE to get 2 years out of a top end.
