Blasters have always been oil injected. You don't need to waste your money on a block off kit. Just remove the clutch cover and pop off the e-clip that holds the oil pump drive gear on. Remove the drive gear and pin and replace the cover. The oil pump itself will act as the block off plate. Remove the oil injection line at the carb and cap off the port. Mix you up some premix and your good to go.
