Can anyone tell me what brand timing plate this is? It has 10 degrees either way.
Another question. I look like it set on 0 or .05 degress advance is this right? What do you guys think?
I would have to say it looks like a Ricky Stator plate. It is cast just like Ricky's, but I guess it could be another brand, but most others are made from billet aluminum (why, it doesn't show, and it's not a stress load item). It looks like it is set around 1 degree advance. :cheers:
not sure about the plate, but it looks like 1 degree advance.
also I would replace the stator cover gasket, and make sure the wire grommet it not leaking. you have alot of corrision in there. :bolt:
462564[/snapback]
I had water in it from may last ride also. It is leaking.
Thanks for the guys for the answers.
